January 17, 2018, 11:02:42 AM *
Author Topic: Gyro Meat on BubbaKeg (pics)  (Read 61727 times)
Author: K Kruger
2 t dried thyme
2 t dried Greek oregano
1 1/2 t dried marjoram
1 1/2 t minced fresh rosemary
1 T Kosher salt
1/2 t ground black pepper
1/4 t ground white pepper
1 medium onion, peeled
1.5 lbs ground lamb
1.5 lbs ground beef
16 ounces plain yogurt
Pinch kosher salt
1 tablespoon olive oil
2 teaspoons red wine vinegar
Yield: 1 1/2 cups
sconner
Resident Keg Mad Scientist
sconner
herb risotto and salad
Opa!
...seconded!
RB
Kegger,
