December 05, 2019, 11:03:15 AM *
Author Topic: Got Leftover Turkey? Turkey Andouille Gumbo  (Read 47297 times)
2 - 3 medium onions
3 - 4 ribs of celery
4 - 5 cloves of garlic
3 - 4 whole bay leaves
Quarter the onions
1 cup vegetable oil
1 cup flour
4 - 5 medium onions, chopped
3 - 4 ribs of celery, chopped
4 bay leaves
4 - 6 quarts turkey stock
Leftover turkey meat
Salt, to taste
Water, as needed
Thanks Cajunator!
Cajunator,
