February 23, 2018, 11:13:16 PM *
Author Topic: Tip Top Temp on a BKK 5000  (Read 2994 times)
yycbanjopicker
« on: July 16, 2017, 11:18:57 AM »
Hi:
Does anyone have any thoughts/experience on using a TTT on BKK5000 (with the ash-pan at the bottom)?
How hard is to set the temperature if you still have to deal with the "dial" at the bottom?
I'm thinking of trying one out... If not that, does anyone know of any ATCs that can be used without any modification of my Keg?
Thanks!
norm
« Reply #1 on: July 16, 2017, 04:48:42 PM »
I use tip top temp on my keg 5000 i let the bottom dial and the top dial full open (at 5 ) and control the temp with the tip top temp with no problem,
yycbanjopicker
« Reply #2 on: July 16, 2017, 09:41:42 PM »
How do you fasten yours? Is there a risk of it blowing off or anything?
Sent from my iPhone using Tapatalk
« Reply #3 on: July 17, 2017, 04:11:23 AM »
I have been using the TTT for 2 yrs. on my 5000 I use magnets I got at home depot called super magnets here they are there 3 in a pkg. part no. is 07047  I put the 3 inside the TTT in a triangle  on the keg open top vent all the way and set the TTT for what temp, I would make a test run with the TTT set at 2 and bottom vent first notch is closed so I will set it at between the second and third notch. here's the magnets I use. the one's without adhesive 07047
https://www.magnetsource.com/Consumer%20Pages/SuperMagsCRFT.html
norm
« Reply #4 on: July 17, 2017, 04:27:23 AM »
I use magnet whit no problems, and i always cull open the bottom and top dial, i control the temp only with the ttt
« Reply #5 on: July 17, 2017, 04:31:56 AM »
I leave mine on all the time but I have a rain cap on.
