May 21, 2019, 05:31:29 AM *
Author Topic: Gasket Replaced  (Read 2507 times)
« on: June 04, 2017, 08:51:59 AM »
Finally got around to replacing my old hard gasket, amazing the difference in the old and the new.  The old is flat, hard and no flexibility at all, the new can be rolled into a ball.  Couldn't be easier, just snap the old one out, clean the rim, and snap the new one in.
Doing ribs today, here is the white smoke billowing at startup, all coming out the top, nothing around the seal.
« Reply #1 on: June 04, 2017, 07:47:14 PM »
I've got a replacement gasket for mine I picked up about 2-3 years ago...I keep telling myself I'll swap it out soon as I start seeing any side smoke....but it seems the old one forms into the PERFECT seal, because it is pretty well holding air tight...though it is hard as a rock.  I think it will take physical damage to destroy it now....
« Reply #2 on: June 05, 2017, 05:44:53 AM »
Bob, if it's not too late.... I suggest you save a few of those clips from the old gasket in case one should pop out or break on the new gasket.
« Reply #3 on: June 05, 2017, 05:48:27 AM »
Thanks Nate, not a bad idea.  I soaked the old gasket in a tub of water thinking it may loosen up a bit but no luck.  I think next time I may try the Nomex gasket on top and bottom and adjust the lid if necessary.
« Reply #4 on: June 05, 2017, 08:30:18 AM »
where did you buy the new gasket?  I am searching the web for it and I can't find one.
« Reply #5 on: June 05, 2017, 12:32:03 PM »
Only place I know of is OMC.  Just call customer service for parts.  Total cost is around $42 US with shipping.
« Reply #6 on: June 05, 2017, 02:04:50 PM »
Ok. Thanks !!
« Reply #7 on: June 05, 2017, 04:54:11 PM »
Buy 2 (or 3)
Same shipping rate
« Reply #8 on: June 06, 2017, 08:20:25 AM »
I just called them.  The lady told i need a 6 digit number off the keg to get the right part #.
I said "i thought there were only 3 models, a 2000 - 4000 and 5000.  I have the 4000".  She insisted that was not enough information to give me the gasket price.
So now i need to search my keg for a 6 digit model number i guess tonight.   Are there more models that i am unaware of?
« Reply #9 on: June 06, 2017, 09:19:37 AM »
td,
here's the part name and number OVEN SEAL GASKET: BSP05521
« Reply #10 on: June 06, 2017, 10:40:46 AM »
td,
thank you!  hopefully with that info they can take my order.
Thew
NYC - natch
« Reply #11 on: June 09, 2018, 01:25:00 PM »
td,
i emailed them last year. (then things got crazy and i never followed up)
but they gave me a different number
"Thank you for contacting Onward Manufacturing.
You can order a replacement gasket by calling our customer service line at 1 800-265-2150- be sure to reference file # 1311882."
any idea which number is for what?
ism is a retrovirus
http://tinyurl.com/3eqr336
« Reply #12 on: June 09, 2018, 02:02:25 PM »
I have a spare gasket for mine, thought I would get a photo of the gasket and part number and post but it's just in a plastic bag with no part number on it.  I would think all the versions of the keg use the same gasket.
Just call OMC customer service with the numbers on the stick on the back of your keg and they should be able to get you a gasket.  These days it's all in the customer service person you talk to.  So many rookies, so little transfer of knowledge......
beefeater
« Reply #13 on: June 09, 2018, 05:03:18 PM »
I ran into the same issue when I called to get a replacement top dome. I gave the numbers and mfg date off my keg and she said it was a bad number. She insisted she wanted a 6 digit number. She then told me my unit had been discontinued. Finally put me on hold and and spoke to her supervisor who apparently pointed her in the right direction.
basshawk84
Newbie
« Reply #14 on: February 21, 2019, 01:34:56 PM »
I just called OMC and they are out of stock on the gasket.  They took my information and said they would email me back when they have an ETA from their supplier.  Hopefully that is soon.  I've got part of my gasket that pulled out and for the life of me, I can't get it back in place.  In the meantime, every time I cook on it all of the charcoal burns up since I can't cut off all of the air.
