January 18, 2018, 03:02:49 AM *
Author Topic: Error Message: "Deprecated..."  (Read 7893 times)
78 T140E
Davie, FL
« on: June 02, 2016, 03:28:20 PM »
What's up with the forum?  I'm getting this error message at the top of the window:
     Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/bigsteelkeg/forum.bigsteelkeg.com/Sources/Load.php(225) : runtime-created function on line 3
I do not see ANY "profile avatar photos".  Is it just me, or do others see the error also?
Walter
« Reply #1 on: June 02, 2016, 05:09:53 PM »
Rich can't sign in but he reported on the FB page that there's a problem and the IT guys are looking at it
« Reply #2 on: June 02, 2016, 05:17:21 PM »
I got the same or at least I believe it is the same message when I tried to post. It did post I just saw the error message. If that helps.
« Reply #3 on: June 02, 2016, 09:28:06 PM »
I got it too.
RIght after posting and refreshing the page.
Most likely something was upgraded and the code in the file  Load.php has a like with a command /e.
Ok I just looked it up, php was probaly updated, maybe when they did a system update.
http://stackoverflow.com/questions/15454220/replace-preg-replace-e-modifier-with-preg-replace-callback
« Reply #4 on: June 04, 2016, 11:08:55 AM »
I had trouble logging in, appeared I couldn't.
I closed the tab, reopened and it came up with me logged in.
Kind of have to do things twice to refresh.
« Reply #5 on: June 06, 2016, 06:36:20 PM »
Phone does not work, computer does.
To get rid of the messages you need to click the page to go back to the home of the forum.
« Reply #6 on: June 07, 2016, 02:43:13 AM »
Just a heads up.
Phone works for me.
I'm getting that message too.
« Reply #7 on: June 08, 2016, 07:18:50 AM »
Should be resolved now.
Some heavier lifting to do in the long term. More updates to come on the SMF framework...
78 T140E
Davie, FL
« Reply #8 on: June 08, 2016, 10:25:41 AM »
Yep, it seems to be back to normal now.  Thanks for the update.
Walter
« Reply #9 on: June 08, 2016, 02:06:49 PM »
Yup looks good here to!
« Reply #10 on: June 08, 2016, 02:16:25 PM »
Thank You!
