February 17, 2020, 06:31:16 AM *
Author Topic: Lower Cost Maverick ET732 and ET733 Probes Replacement  (Read 25215 times)
« on: May 20, 2016, 04:40:56 PM »
After 2 years of many cooks my Maverick grill temp probe failed.
I looked at Amazon for a replacement.  The original ones were fairly expensive.
I found a pair at a much lower cost, (less than on EBay).
http://smile.amazon.com/Accuon-ACU0235-Replacement-Probes-Thermometer/dp/B017JWPX58?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
They come with a plastic insert at the cable crimp area that might help with moisture going into the probe.
I still sealed with High Temp RTV to make sure.
lbyer
« Reply #1 on: May 21, 2016, 05:01:38 AM »
Looks like a great deal, thanks! Have you checked their accuracy?
BKK 4000
BroilKing Baron 440   GASSER
GRILLGRATES
DIGIQ DX-2 WITH 10CFM FAN
« Reply #2 on: May 21, 2016, 05:08:19 AM »
Only plugged in at room temp...that checked out.
Next cook is a week away...I'll update then.
« Reply #3 on: May 21, 2016, 06:30:42 PM »
Thanks for the info!
« Reply #4 on: November 01, 2016, 06:11:48 AM »
Ordered it and received it yesterday and put on my 732 to check and both said the same as my room temp.
« Reply #5 on: November 01, 2016, 06:27:10 AM »
Forgot to update.
New probe not only matches others from the 732 and 733 units....but, also match the new unit from Thermoworks (SMOKE).  Note not using replacement probe on "SMOKE" only matching readings.
lbyer
« Reply #6 on: November 01, 2016, 04:16:46 PM »
Forgot to update.
How do you like the Smoke unit? I'm thinking of buying a unit to replace my 732, but I wanted to get some "in the field" test data...
BKK 4000
GRILLGRATES
« Reply #7 on: November 01, 2016, 06:35:19 PM »
I bought a Smoke. I use it Sunday on a tri tip. It works great and is super easy to program.
« Reply #8 on: November 01, 2016, 09:34:08 PM »
Works great and much easier to set than Maverick.
Has some quirks with high/low alarms and with no prob warning.
No easel stand for receiver only cord to go over your neck or hang some place.
BIG PLUS ....Probes are water proof...no need to seal ends.
Magnet on back of sender unit so it will be out of the way on the Keg and not get knocked off a side shelf.
« Reply #9 on: November 04, 2016, 03:36:08 PM »
They have a sale going on at thermoworks
http://www.thermoworks.com/Thanksgiving-Bundle
Not sure if it that good of a savings...
« Reply #10 on: November 10, 2016, 02:13:00 PM »
I know I have asked before but how accurate do you really need? I have kinda decided +/- 2ºF is fine. Thoughts?
