February 22, 2019, 07:21:54 PM *
Author Topic: Keg Grilling Cabinet  (Read 3532 times)
« on: October 26, 2015, 04:40:38 PM »
A while back I ordered one of these and never put it together but recently Steph and I have acquired a new keg thanks to Rich and Broil King raffling one at Kegtoberfest Smiley
I assembled the Keg yesterday when we got back and today I was home most of the day so it became our project to assemble the cabinet. There were a few screws missing that a trip to Lowe's fixed but I can tell you that it's not that fun to put together Tongue
So.....for those wanting a closer look at it, here you go. The Keg is not in it yet as I have to move the cabinet to the deck and then the 5000 will call it home.
« Reply #1 on: October 26, 2015, 04:44:31 PM »
Cool! I like it!!!
PascL
Keg Hero Of The Month - 3x Throwdown Champion
« Reply #2 on: October 26, 2015, 05:31:14 PM »
love the look of it and have been eyeing it for a while,
Im still curious if the door needs to be open to do a cook to allow the air in, let us know!
Cookin' in the cold
« Reply #3 on: October 26, 2015, 05:46:42 PM »
Nah, doors can be kept closed. That cabinet is not sealed air tight. The ambient air inside is all it would need.
Kmatt
Hero of the Month - Throwdown Champion
« Reply #4 on: October 26, 2015, 08:18:37 PM »
I want one but I also want to build an outdoor kitchen on my deck.
PascL
« Reply #5 on: October 27, 2015, 07:27:28 AM »
I'm on the fence too, just want to change my storage situation so I don't have to run to the garage for everything, however anything outdoor has gotta resist the wrath of Canadian Rocky Mountain winter weather
Sent from my iPhone using Tapatalk
Cookin' in the cold
« Reply #6 on: October 27, 2015, 07:47:17 AM »
Michael (Skins) has one already in use, he can tell you thoughts on it better than I since he's had his in action.
« Reply #7 on: October 28, 2015, 10:53:32 AM »
Weather has improved so we got to set the new keg in the cabinet.
« Reply #8 on: October 28, 2015, 11:14:11 AM »
May look better with the handles off.
« Reply #9 on: October 28, 2015, 11:20:29 AM »
Looks great!
« Reply #10 on: October 28, 2015, 11:23:31 AM »
I am leaving them on, I actually am using the left side shelf to hang stuff on plus I don't want to try and attempt to match the paint and fill in the holes like I did on the 2000. Overall I like it, time will tell how it holds up. We will keep it covered when not in use. I can tell you that the bottom vent is REAL close to the door. I don't think the 2000 or 4000 would have that issue.
« Reply #11 on: October 28, 2015, 11:47:15 AM »
As you can tell by the pics above, I am seasoning the grate. I am also trying to get a feel for the vents, it may take a bit of adjustment going from a slide bottom vent to the rotating one. The old way allowed A LOT more air into the bottom but maybe it was never needed. I guess not since there is no way the 5000 can let that much in by comparison.
Anyhoo. This is how the cart keeps the keg snug in there, pretty nifty I'd say. It has 4 of these, 2 in front, 2 in back. You can adjust them to shim it where you want it.
A view from the top showing both front shims.
And Vin, here's how I am using that shelf. It comes in handy.
« Reply #12 on: October 28, 2015, 11:51:15 AM »
If you look at those pics with the lump being lit you can barely see one of the three stickers that tell you not to fill the lump up past the holes Tongue Those are being burnt off as we speak, lol.
« Reply #13 on: October 28, 2015, 12:18:47 PM »
I used two shelf hook sets and screwed them in the left side of the cabinet
« Reply #14 on: October 28, 2015, 12:36:33 PM »
Was yours missing any screws like mine? I had to run to Lowe's to pick up some #10 24 3/8 screws as I was missing 2. Frustrating!! As a matter of fact, the Keg itself had some screws missing according to the instructions at least. For the front handle, it showed 4 of the same sized screws but only had 2 the same and 2 that were the same screw but longer so I figured that I needed to use the 2 long ones on bottom on 2 shorter ones on top. It worked. There were also 2 little oval gaskets with 2 holes in it that I figured must go in between the handle and the keg itself due to the spacing of the holes. That's where I put them anyway! Tongue
